-   -   HELP with door lock (https://minicooperforums.com/forum/general-tech-8/help-door-lock-2113/)
04cooperS May 26, 2009 11:48 PM
HELP with door lock
hi my 04 cooper s driver door will not unlock using the key or the switch inside the car. i can use the key to turn the lock but i can only open the car from the outside and not the inside. anyone knows what i need to replace here. any info will be great. thanks in advance
bad venge May 27, 2009 06:33 PM
Sounds like the linkage or the actuator is bound up
04cooperS May 29, 2009 06:08 AM
i removed the cover on the door and the line from the door handle seems to be intact. if the actuator the small black box next to the silver door handle?
thank you
Igorokk Jun 11, 2009 07:53 PM
HELP with door lock
Ok guys Im trying to get the wii 64 to work on my wii but when I try to upload from sd it just get an error. What am I doing wrong? Any help you guys can offer would be great or what yall are using to play the 64 games on your wii.Thanks
