High Mileage Mini
Hello, my R52 Cooper S Convertible is now post 210,000km. Somewhere around 124,000 miles. I've been pretty good with regards maintenance, and ultimately want to keep the car "forever".....or at least to 300,000km. (Sidebar: I'm tired of throwing things away that just need a bit of repair). She sleeps in the garage in the winter, so that helps from an overall perspective with salt/rust etc. I haven't seen a great deal of rust but keep looking all the time...big fear of rust!
I'm looking for some advice from any other high-mileage-owners. What are some of the things that you have run in to - could you take a look at the list below and let me know if I"m missing anything please? I know this will cost $$$ but that's ok, given that I want to keep the car running just as well as she is now. Work done between 100,000km – 150,000km • Power steering reservoir and cooling fan • Thermostat • Serpentine Belt • Air Filter assembly • Changed Coolant and transmission fluid • Water Pump • Serviced super charger • Replaced water pump and radiator hose • New Battery • New clutch and slave assembly, new (smaller) overdrive pulley • Front shocks Work done between 150,000km and 200,000km • Thermostat • Gear box selector cables • Power steering cooling fan • Alternator • Right front engine mount and Transmission mount assembly • Left front ABS sensor • New battery • Replaced handbrake cables Work to be done now at 215,000km • Serpentine belt and tensioners • Water pump • Thermostat • Service super charger • Power steering fluid flush, replace cooling fan • Replace vacuum hoses as required (currently have P1498 fault code) • Engine mounts and/or transmission mounts (car is vibrating when stopped at red light) • Replace rear shocks, consider replacing front (already done but other ones might help old age) and consider replacing front bushings, ball joints and strut bearings • Adjust handbrake (too “loose”, too high) • Check CV joint boots • Service air conditioner • Replace spark plugs • Replace power steering pump • Replace oil pump • Replace timing chain (with guides etc) • Add GTT Strutbrace • Replace clutch (might as well given the engine is probably coming out) |
