-   -   Horn Problem (https://minicooperforums.com/forum/general-tech-8/horn-problem-2371/)
warthog Aug 29, 2009 12:00 PM
Horn Problem
Any suggestions on how to troubleshoot horn problem on my 2004 Cooper S? When activated, a 'relay?' seems to be clicking near the fuse panel but the fuse is OK.
Any suggestions?
bad venge Aug 31, 2009 09:20 PM
check at the horn for voltage ... 12 volts present then Bad Horn ... No 12 volts then you'll have to trace the wiring back to the relay ...
warthog Sep 1, 2009 06:08 AM
Thanks,
From your comment, I guess there is a horn relay? That is apparently what I hear clicking but have been unable to locate. Is it near the fuse panel?
FLMINI-Mech Sep 20, 2009 05:07 AM
The failure rate of the horn assemblies (there are 2) is immense. They often fill full of water or moisture and then fail. As a previous poster said, check for 12v power and continuity with ground at the horn connector when an assistant presses the horn button.
