Intermittent misfire
Old Feb 8, 2011 | 06:59 PM
ShewbodMini's Avatar
Default Intermittent misfire
Hello, I have recently purchased an 04 mini with 100,ooo kms. It is under dealer satisfaction warrantee, and they have fixed a number of things... New standard transmission, clutch, fuel injector and coil pack. I continue to have an intermittent misfire, not predictable in any way, but often in second gear while the engine is under load. The car is in the shop now and they are trying to get to the bottom of it, and have not been charging me for this work, as it is still under then satisfaction warrantee. I asked for a compression test, and they said that may be a next step and that a full tune up might be needed. They also suggested they might need to buy the car back from me, but I love it and since so much has been done, I don't want to give up.
Any thoughts?
Old Feb 8, 2011 | 07:36 PM
could be bad fuel injector (sounds like they replaced one) fuel pump , plugs/plug wires
build up on the valves ,
Old Feb 8, 2011 | 07:53 PM
Thanks, I will ask about those things. What about a flywheel?
Old Feb 10, 2011 | 10:13 AM
rusty3096's Avatar
Did they tell you witch cylinder is misfiring ? I would have them do a compression test and a cylinder leak down test . This should give you a good idea of the health of your motor. a scan tool should tell them the cylinder or cylinders that are misfiring . let me know what they find and I'll see if I can help.
Old Feb 11, 2011 | 06:11 AM
Default Intermittent Misfire
Hi thanks, I got the car back last night, and on the first drive it seemed great! They said cylinder 2 had been misfiring and they replaced all wires, and plugs. It seemed to drive with much more power/ pep. The misfiring did not happen at all so I will now drive it and cross my fingers it is gone, **
NotDFace
Apr 11, 2015 07:01 PM
SageSkaggs
Feb 27, 2014 09:08 AM
coopy56
Nov 22, 2011 09:56 PM
JimMigliaccio
Oct 11, 2011 08:36 PM
lisalevi
Mar 28, 2009 11:39 AM
