-   -   Key Issue? (https://minicooperforums.com/forum/general-tech-8/key-issue-5338/)
Tommy G Mar 23, 2012 11:18 AM
Key Issue?
my 2004 mini won't start. lights come on but key will not start the motor. Found battery was not holding charge and replaced with a new one and still nothing
bad venge Mar 23, 2012 01:47 PM
Check if starter is getting voltage (likely Not) then trace backwards solenoid or relay failure more likely then the key failing
