location of flasher for led ligjt replacement
Greetings, I own a 2005 mini s and replaced my turn signal lights, front and back and need to order the appropriate flasher box so they don't flash so fast. Would you know where the flasher box is located so I can match it up and order the right replacement for led turn signal lights. ? Ty
I couldn't find one to work but added ballast resistors from superbrightleds.com this slowed down the rate
