Mini 2004 S Starting issues
Old Apr 13, 2011 | 10:03 AM
traynor's Avatar
Default Mini 2004 S Starting issues
On my 2004 S the first time I go to start it in the morning it starts hard and runs poorly for a couple of minutes. Then clears up and is fine the rest of the day. Then it starts over again the next day?
Old Apr 14, 2011 | 12:08 AM
Weather conditions ?
Old Apr 14, 2011 | 05:41 AM
traynor's Avatar
it's been cold 30deg and higher but it doesn't matter cold or warm wet or cold it acts the same. I have it in the repair shop they tell me it's bad injectors leaking into the cylinders.
Old Apr 14, 2011 | 08:42 AM
I was thinking either the cold start enrichment circuit or bad injectors
Old Apr 14, 2011 | 11:51 AM
traynor's Avatar
I looked at the plugs they were fouled and you could see that the cylinders were wet. So I guess replacing the injectors is the right step. all be it not cheap.
Old Apr 14, 2011 | 12:38 PM
shop around many are upgrading stock injectors on the cars to larger might be able to find a set on ebay ect
Nolamike
Nov 23, 2013 03:03 AM
miniconor
Mar 22, 2010 03:35 PM
efiguero
Oct 15, 2009 01:26 PM
fuhrius
Apr 6, 2009 10:02 PM
Jaimee
Mar 11, 2009 08:17 AM
