-   -   mini cooper footwell module (https://minicooperforums.com/forum/general-tech-8/mini-cooper-footwell-module-10727/)
Jackson A Mclean Jan 23, 2018 06:47 PM
Any Body have problems with the footwell module ? seems to me that might be my problem
PhatBrian Feb 7, 2018 11:47 AM
footwell modules are common issues in mini as well as bmw. if your footwell module has corrosion you need to see where water is getting in from. most of the time the sunroof drains detach and drain directly down the a-pillar inside the vehicle.
Minitobe Mar 21, 2018 07:23 PM
It could also be covered under warrenty from mini. Give them a call.
PhatBrian Mar 21, 2018 08:05 PM
They won't cover it if it has water intrusion.
Minitobe Mar 21, 2018 08:09 PM
Maybe true...it is an easy swap with a unit that has the same part number. ISTAP can program and code it with no issues.
