-   -   No reverse (https://minicooperforums.com/forum/general-tech-8/no-reverse-14488/)
KPLYNKE Mar 1, 2026 01:07 PM
No reverse
2012 mini Cooper countryman all 4S no reverse after replacing Clutch. And out there on the countryman S with all four, had to remove the shift lever assemblies that go in the transmission to get it out from underneath the car. Not sure if it was aligned correctly when I put it back in. Now the shift lever doesn’t go far enough left and up to get reverse does anyone have any information on this. Very little information on the countryman all 4S.
ECSTuning Mar 11, 2026 04:01 PM
Check the shift cables attached above the transmission, they might be on wrong or not hooked up.
