Operating Fluids
Old May 26, 2005 | 11:57 PM
1fstmini's Avatar
Default Operating Fluids
SUBJECT
MINI Operating Fluids
MODEL
R50 Cooper, R52 Cooper Convertible, R53 Cooper S
SITUATION
Application
Part Number
Description
Engine Oil (1 Quart)
Engine Oil (55 Gallon Drum)
07 51 0 143 829
07 51 0 031 132
MINI Synthetic Oil SAE 5W-30
6 Speed Automatic Transmission GA6F21WA Cooper S Only
83 22 0 402 413
MINI ATF JWS 3309
1 Liter Bottle
Note:
-Pan removal requires 4 liters to refill.
-Torque Converter replacement requires 4.5 liters to refill.
-Transmission replacement requires 6 liters to refill.
ECVT Transmission Fluid
83 22 0 136 376
Esso EZL799
Manual Transmission Fluid
up to 7/2004 production R65 5 Speed & Getrag 285 6 Speed
83 22 0 140 516
Texaco MTF94 Lifetime Fluid
Manual Transmission Fluid from 7/2004 production Getrag 252 5 Speed and 285 6 Speed
83 22 7 533 818
MTF LT-3 Lifetime Fluid
Antifreeze/Coolant
82 14 0 031 133
Antifreeze/Coolant 1 Gallon
Power Steering Fluid
82 11 0 148 132
Pentosin CHF 11s
Brake Fluid
81 22 0 146 735
DOT 4 Fluid
Convertible Top Hydraulic Pump Fluid
54 34 0 394 395
Hydraulic Oil
Air Conditioning Refrigerant
Sourced locally using independent supplier
HFC-R134a
Air Conditioning Refrigerant Oil
82 11 0 148 908
PAG Oil (Polyalkylene Glycol)
Old May 27, 2005 | 02:06 AM
XCM828's Avatar
Default RE: Operating Fluids
Great stuff! I'm starting up a little Mini Tech section in this forum, and all of these are first on the list! Great job!
Old May 27, 2005 | 12:46 PM
Patrick's Avatar
Administrator
if you guys want a section, let me know. like a DIY section, or whatnot.
Old May 27, 2005 | 10:29 PM
1fstmini's Avatar
that would be good..........i have access to all of the service and parts bulletins to post on here when i find new stuff or if someone has a technical question.
Old May 27, 2005 | 11:25 PM
Patrick's Avatar
Administrator
what exactly do you do?
Old May 28, 2005 | 11:08 AM
1fstmini's Avatar
Im a parts/dinan specialist at bmw/mini dealer.
Old Feb 5, 2010 | 05:57 PM
04minis's Avatar
Does anyone know where I can get these fluids in Canada other than the BMW/Mini dealer?
Old Aug 30, 2011 | 09:09 AM
  #8
darlhohn's Avatar
Do you know anything about the automatic transmission code P0700?
Old Aug 30, 2011 | 10:34 AM
  #9
JMBL's Avatar
Member
1stmini,
Can you tell me if oil overfill - say by about 3/4 of a quart -is potentially harmful? I have a 2011 basemodel hatch. Sorry if I'm addressing this question in the wrong section, but I saw that you are a tech, and this issue has just cropped up.
Thanks in advance for any info you can provide.
Old Mar 30, 2012 | 07:12 PM
  #10
CLH's Avatar
CLH
I can't find anywhere how much (in Litres) the Power Steering and the Brake Fluid are. This is for an R53 Cooper S, so if anyone could help out that would be great.
sneedspeed
Oct 29, 2013 01:39 PM
Aug 21, 2013 10:09 AM
