Power Steering issues
Old Nov 18, 2007 | 03:32 PM
thebigwubler's Avatar
Default Power Steering issues
2004 Mini Cooper 40k. My power stearing electrical assist is not shutting off with the key. The only way I could get it to stop was to disconnect the battery, and now I have unplugged the power supply going into the steering pump. I am wondering if it is a solenoid or a relay that has gone bad and what I might do to fix it. Appreciate any thoughts and help.
Mitch
Old Apr 13, 2008 | 12:52 PM
Pleasurepig's Avatar
Default RE: Power Steering issues
I had a bad day Friday. My'03 S w/70K didn't avoid a large pothole and the force was so great it popped my glove box open and flattened both tires on the right side. Thank god for run flats w/roadside hazard warranty. Shut the car off after the incident and when I restarted the car, I had no power steering. No leaks, no visible damage. I'll start by checking connections and fuses, but....any suggestions?
Old Apr 13, 2008 | 01:25 PM
Sounds like either the relay , or solenoid has welded on ... I'd get the wiring diagram and start backtracking ...
Old Apr 16, 2008 | 07:09 PM
RallyCOOP's Avatar
ORIGINAL: thebigwubler
Mitch
This is one of the failure modes for the car, mine did the same and was replaced under warranty. All of the controls for the pump are internal to the pump. The dealer wants $600 plus for a new pump not counting installation.
Do a search for a company by the name of BBA Reman. they rebuild the pump for $200 with a warranty for life! the turn around time is three days.
If you are handy with tools you can replace it yourself in 1/2 hour.
Sorry to hear about your troubles and hope this helps.
Aug 19, 2013 01:11 PM
cdninoh
Jan 10, 2008 01:01 PM
what?!
Aug 25, 2007 01:48 AM
Randy Lawson
Jun 26, 2007 06:51 PM
Kanna
Jun 20, 2007 09:10 PM
