Pricing for Repair on Antenna
Hello,
Well bad luck must of followed me today as I backed into my garage door and completely took off my antenna on my 2007 mini. Does anyone know how much this will cost to repair at the dealership?? |
1 Attachment(s)
Can you provide the vin for your MINI? Is it a Cooper or Cooper S? I can get you the correct part. You can take the part to a local MINI independent shop for install, as it will be much less than what the dealership will charge you. You can find a shop near you using this site HERE.
Do you just need the antenna mast? Subby version and regular version HERE. http://www.pelicanparts.com/catalog/...96772-M253.jpg Or do you need the base as well? The base without navigation is HERE. The base with navigation is HERE. Again, if you send me your vin number I can confirm if you're unsure. :) Attachment 2371 |
