problem with lights
I just bought a 2002 S and I'm having problems with lights. Some of the lights work and some don't. For example:
- the left signal lights all work, none of the right side work (but the signal flasher blinks correctly on both sides) - the left low beam works, the right doesn't - the right high beam works, the left doesn't - the left front parking light works, the right doesn't - the right rear parking light works, the left doesn't - the top light on both rear sides doesn't light (what is it for?) I've swapped bulbs, checked fuses Any suggestions? Thanks |
check for voltage at the sockets on the bulbs that are not working
sounds like you have a hell of a mess ... did the car sit for a long time ???? I'm thinking corrosion or rats/mice ate the wiring harness |
lights problem - operator error
Doh! The problem was a 50 amp Fusible Link.
