R58 indicators not working
I have a 2013 Mini Cooper Coupe. The drivers side indicators all work, however only the passenger front indicator works, the side and rear passenger does not.
I have swapped bulbs, tried a known working rear side and rear indicator and cleaned the contacts and it has not fixed the problem. I tried a circuit tester and am not getting any power/voltage showing. All other electrics work fine including all lights, both rear running and brake lights work fine and there are no error codes showing up. I have even tried disconnecting the battery for 30 mins Can any one point me in the right direction of what the problem could be? Does it sound like a fault with the FRM unit? |
hello,
Check the fuse and also check the line itself, the wire might have been cut or kinked |
