Radiator fan 2009 Cooper convertible
I have now replaced my second radiator fan. My mechanic says the fan will come on at the appropriate 210 degrees and will cool the engine but the fan never cuts off once it comes on. The only way to make it stop is to turn off the engine. Once the engines gets to 210, it's follows the same process. No wonder I am replacing fans. Is there a software update that allows the fan to disengage once the engine is cool?
Originally Posted by minime2017
(Post 24115)
Same problem on a 2009 hatchback...
YEP...Same problem here.
It is NOT air in the system. Changed the thermostat housing because of a leak. It did it before...It does it after. The system was well bled after the housing change. |
