-   -   Recall : Tank Leakage Diagnostics (https://minicooperforums.com/forum/general-tech-8/recall-tank-leakage-diagnostics-81/)
1fstmini May 26, 2005 10:35 PM
Subject - Voluntary Emissions Recall Campaign : Reprogram DME for Tank Leakage Diagnostics
Model - MINI Cooper/Cooper S from start of series production through May 2004.
Situation - Tank leakage diagnostics does not run corectly due to error in the DME software. As a result, the Check Engine Soon light will be illuminated in the case of leakage in the evaporative system.
So in normal people talk......Our cars and also BMW's have a check system to tell if your gas tank is sealed and there are no leaks like from the gas cap which will throw a light to tell you that theres a leak.
XCM828 May 27, 2005 01:49 AM
RE: Recall : Tank Leakage Diagnostics
Whew, I think I'm safe. Ordered my Mini in August 2004.
