-   -   Replacement spark plugs (https://minicooperforums.com/forum/general-tech-8/replacement-spark-plugs-4466/)
orca17 May 30, 2011 04:08 PM
When my '03 Cooper hit 120K miles I decided to replace the original spark plugs. Having used Bosch plugs for years with excellent results I bought a set of Bosch Platinum 2+ plugs and installed them. My mechanic told me that Bosch plugs are not a good idea in this particular engine. There have apparently been cases in which Bosch plugs have worked loose and blown out of the cylinder heads while the engine is running, causing damage under the hood. I bought a set of NGK Platinum plugs and replaced them. Just wish I had known this before I bought the first set of plugs...
PelicanParts.com May 18, 2012 11:13 AM
DIY guide for replacing your spark plugs and wires: Pelican Technical Article: MINI Cooper - Spark Plug and Cable Replacement
We also carry the NGK spark plugs for your MINI: Project 7: Spark Plugs and Cable Replacement - Page 1
