Sticker removal....help!
I'd like to remove the airbag sticker on my dash.
Any suggestions ? Was going to heat gently with a hair dryer and use some dental floss to go between or just try to peel off. After that I planned on removing the remaining glue with WD 40. I have the anthracite dash on a 08 "S" convertible. Thanks for your input Thunderhead |
RE: Sticker removal....help!
I used a hair dryer and it was a pain to get off but did come off. I used a little gas on a rag to get the remaining glue off. (Someone will probably roast me for being so barbaric, but gas works pretty good if you use common sense.)
[:@]3M adhesive remover is FAR FAR safer then gas
| All times are GMT -5. The time now is 06:03 AM. |
