Sticking re-circulate switch
Old Dec 15, 2010 | 12:33 PM
Technique's Avatar
Default Sticking re-circulate switch
Just purchased a second Mini (2005 Coupe). The re-circulate switch on the heater panel is stuck "ON". Any suggestions as to a fix?
Old Dec 15, 2010 | 04:15 PM
There are two types of HVAC panels one has a round dial you set the digital temp , the other has a red /blue dial whicg one do you have ?
Old Dec 16, 2010 | 09:46 AM
Technique's Avatar
The red-blue manual set type. All the push buttons (rear window defrost, re-circulate, AC) are impossible to push with the re-circulate stuck ON. I now suspect some previous owner has used a desolvant cleaner on the panel. Do you know of a lubricant that will not dissolve or weld plastic.
Old Dec 16, 2010 | 04:49 PM
It might be best to remove the unit and dissassemble and try to remove the PCB and break them loose...
OR buy This :
http://cgi.ebay.com/ebaymotors/02-08...Q5fAccessories
Old Dec 17, 2010 | 06:39 AM
Technique's Avatar
Thanks; I agree that replacement is the correct option. If one tears into it enough to remove the uint, just replace the panel as a set.
Feb 21, 2014 03:48 PM
Feb 21, 2014 03:37 PM
Doug B
Jan 7, 2009 10:13 PM
slhess57
Oct 2, 2008 06:22 PM
mtnmini
May 29, 2008 06:44 PM
