-   -   Sticking re-circulate switch (https://minicooperforums.com/forum/general-tech-8/sticking-re-circulate-switch-3834/)
Technique Dec 15, 2010 12:33 PM
Just purchased a second Mini (2005 Coupe). The re-circulate switch on the heater panel is stuck "ON". Any suggestions as to a fix?
bad venge Dec 15, 2010 04:15 PM
There are two types of HVAC panels one has a round dial you set the digital temp , the other has a red /blue dial whicg one do you have ?
Technique Dec 16, 2010 09:46 AM
The red-blue manual set type. All the push buttons (rear window defrost, re-circulate, AC) are impossible to push with the re-circulate stuck ON. I now suspect some previous owner has used a desolvant cleaner on the panel. Do you know of a lubricant that will not dissolve or weld plastic.
bad venge Dec 16, 2010 04:49 PM
It might be best to remove the unit and dissassemble and try to remove the PCB and break them loose...
OR buy This :
http://cgi.ebay.com/ebaymotors/02-08...Q5fAccessories
Technique Dec 17, 2010 06:39 AM
Thanks; I agree that replacement is the correct option. If one tears into it enough to remove the uint, just replace the panel as a set.
