Thermostat and reservoir question
Old Feb 4, 2008 | 08:37 PM
TJ44's Avatar
Default Thermostat and reservoir question
Good day - I am looking to see if anyone has the shop manual for their Mini Cooper. Would it be possible to find out the temperature where the Mini's thermostat starts to open and the temperature where it's fully open?
Also, is it normal that the coolant reservoir is empty when the engine is cold?
Thanks!
Old Feb 6, 2008 | 07:14 AM
TJ44's Avatar
Default RE: Thermostat and reservoir question
wow, lots of help and discussions here... guess ill find a better site.
Old May 27, 2008 | 09:48 AM
NEWBFORMINI's Avatar
I have the same question to. I have an 04 and am not near a dealer. The reservoir is always low, down to the minimum, does not over heat, but where is the coolant going?
Old Jun 25, 2008 | 07:34 AM
froglips's Avatar
I have heard that the only place to get the manual is from Europe.
As far as the coolant resevoir level goes, at least in my 2008 MCS JCW, it is always at the minimum mark, which is fine. They leave room in this resevoir for expansion, and the max fill line seems to be right at the seem. I would not overfill this resevoir if I were you.
When you ask where is the coolant going, what do you mean exactly? I mean, are you filling it up to some other level, and noticing that it keeps leveling off at the minimum level every time afterwards? IF so, I have no idea where it is going, but I would think that since this is a closed pressurized system,if there is too much pressure due to overfilling, it has to go somewhere outside of the closed pressurized system.
Any coolant puddles on the ground at your house? Or maybe lots of dead neighborhood pets/animalsaround your house all the time because they are licking it up before you notice it? I know, not funny, but heh.
cjstella
Jul 21, 2015 03:20 PM
thebeliever
Jul 6, 2015 12:59 PM
katekilpatrick
Sep 5, 2013 06:38 PM
jtcaoimh
Feb 27, 2012 11:09 PM
thechicgeek
Feb 7, 2009 11:52 PM
