Vacuum Pump 11 66 7 570 813, Inner Orange Seal.
Old Sep 4, 2013 | 10:33 AM
abenor's Avatar
Default Vacuum Pump 11 66 7 570 813, Inner Orange Seal.
Vacuum Pump 11 66 7 570 813, Inner Orange Seal. Is anyone found the seal part number which is not at ETK. wondering if any seal non OE is available. Thanks.
Old Sep 5, 2013 | 01:20 PM
That's the vacuum pump for N12 Cooper engine ( non turbo ).
#1 Vacuum pump
http://www.ecstuning.com/Search/SiteSearch/11667570813/
#2 O-Ring Its the outer seal that goes towards the head. The measurement is in the description.
http://www.ecstuning.com/Search/SiteSearch/11667566483/
Old Sep 6, 2013 | 02:03 PM
abenor's Avatar
#1 Vacuum pump
i need the Inside pump Inner Orange Seal not the front which was not my request as you can read my initial post. Thanks.
abenor's Avatar
I need the Inside pump Inner Orange Seal not the front which was not my request as you can read my initial post. Thanks.
Old Sep 7, 2013 | 12:05 AM
countrycooper's Avatar
Default tire replacement
just found this forum. its nice to know there are others to talk to out there! i have 195/55/16 right now. will it hurt to put 205/55/16 on as replacements?
Old Sep 9, 2013 | 09:29 AM
Abenor - There is no OEM part number that I can find for that orange seal, can you get the measurements in MM and i can try to find one that will match.
Countrycooper - welcome , try the general and start a new thread or the tire, wheels and brakes section.
Old Oct 16, 2013 | 01:40 PM
abenor's Avatar
Vacuum Pump 11 66 7 570 813 Orange Seal Dimension are 84MM. Thanks. Ronny.
Attached Thumbnails Vacuum Pump 11 66 7 570 813, Inner Orange Seal.-vacuum-pump-11-66-7-570-813-orange-seal-84-mm.jpg
Old Oct 16, 2013 | 03:17 PM
  #8
Thanks,
Could not find one that size on the MINI side. Found one close on the BMW side but it only comes in pack of 10. Also its black and 85mm x 2mm. Your best bet would be to match it up at a rubber gasket maker. Also the type of gasket, round vs square for not the shape but the type on the thickness.
http://www.ecstuning.com/Search/SiteSearch/11361406868/
**But there is good news , the Pierburg (OEM manufacturer) direct version is available now.
Vacuum Pump Part # 11667570813
kentuckynet
Feb 11, 2018 09:39 PM
Dec 3, 2014 01:11 PM
