-   -   Vacuum Pump 11 66 7 570 813, Inner Orange Seal. (https://minicooperforums.com/forum/general-tech-8/vacuum-pump-11-66-7-570-813-inner-orange-seal-6476/)
abenor Sep 4, 2013 10:33 AM
Vacuum Pump 11 66 7 570 813, Inner Orange Seal. Is anyone found the seal part number which is not at ETK. wondering if any seal non OE is available. Thanks.
ECSTuning Sep 5, 2013 01:20 PM
That's the vacuum pump for N12 Cooper engine ( non turbo ).
http://www.realoem.com/bmw/diagrams/j/e/229.png
#1 Vacuum pump
http://www.ecstuning.com/Search/SiteSearch/11667570813/
#2 O-Ring Its the outer seal that goes towards the head. The measurement is in the description.
http://www.ecstuning.com/Search/SiteSearch/11667566483/
abenor Sep 6, 2013 02:03 PM
#1 Vacuum pump
i need the Inside pump Inner Orange Seal not the front which was not my request as you can read my initial post. Thanks.
I need the Inside pump Inner Orange Seal not the front which was not my request as you can read my initial post. Thanks.
countrycooper Sep 7, 2013 12:05 AM
tire replacement
just found this forum. its nice to know there are others to talk to out there! i have 195/55/16 right now. will it hurt to put 205/55/16 on as replacements?
ECSTuning Sep 9, 2013 09:29 AM
Abenor - There is no OEM part number that I can find for that orange seal, can you get the measurements in MM and i can try to find one that will match.
Countrycooper - welcome , try the general and start a new thread or the tire, wheels and brakes section.
abenor Oct 16, 2013 01:40 PM
1 Attachment(s)
Vacuum Pump 11 66 7 570 813 Orange Seal Dimension are 84MM. Thanks. Ronny.
ECSTuning Oct 16, 2013 03:17 PM
Thanks,
Could not find one that size on the MINI side. Found one close on the BMW side but it only comes in pack of 10. Also its black and 85mm x 2mm. Your best bet would be to match it up at a rubber gasket maker. Also the type of gasket, round vs square for not the shape but the type on the thickness.
http://www.ecstuning.com/Search/SiteSearch/11361406868/
http://c1552172.r72.cf0.rackcdn.com/367316_x600.jpg
**But there is good news , the Pierburg (OEM manufacturer) direct version is available now.
Vacuum Pump Part # 11667570813
