Vibration noise
I have an 04 MCS with aftermarket wheels and non-runflat tires. Recently I've been getting more and more vibration noise from the driver side rear corner. I had the wheels checked and the are balanced. I just can't seem to figure it out. The vibration is worse when going 40 to 50mph. Anyone have any thoughts as the the cause or cure?
Thanks, Tim |
I'd inspect the inner parts of the tire ... Mini's are hard on the inner parts due to camber
Noise resolved. All this started when I slammed into a huge pot hole or broken asphalt that hit all 4 corners. The damange was two dented rims on the right side, two damaged front control arm bushings and rear hub barings that were destroyed. Now that has all been fixed all I can hear is the gentle hum of my exhaust. All that noise was making my car a lot less fun. Now that it is fixed I'm a happy camper again.
| All times are GMT -5. The time now is 02:28 AM. |
