Wheel stuck
Does anyone know why the wheel won't come off when I've removed the 4 lug bolts?
likely rust is firmly attaching it ... hard impact at the top/bottom to loosen , when you remount clean the inner hub and the wheel with a wire brush and apply a light coat of never seize to prevent it from happening again,,,
If it's really really stuck , I've loosened the nuts a turn or two and drive it a few feet to loosen it |
| All times are GMT -5. The time now is 01:28 AM. |
