Why is there two indicator lights when rear brakes are low?
Old Jun 26, 2012 | 10:24 PM
dcsweet's Avatar
Default Why is there two indicator lights when rear brakes are low?
Rotor on one side was gone, and so was the sensor on my 2006 S, with 73k. There was 2 lights, one I have struggled with and finally got it to go off, which is the brake pads warning, the one that has a reset button by the eBrake. There is another one, the circle with the dashed curved lines around the circle on each side. The front brakes look Ok, not close to be needing replacement. I only changed brakes and rotor on rear right, rear left is fine, both brakes and rotor.
Old Jun 28, 2012 | 11:22 AM
PelicanParts.com's Avatar
Is there anything in the middle of the circle of the second warning light? Like this (!)?
-Jorge
Old Jun 29, 2012 | 08:04 AM
dcsweet's Avatar
the one that had something in the middle of the circle has been reset. This one is just a circle with dashed C on either side
Old Jun 29, 2012 | 11:24 AM
I'm thinking loose or malfunctioning brake sensor in a brake pad?
-Jorge
marc0011
Aug 24, 2015 10:19 PM
HerMiniMan
Apr 4, 2014 10:39 AM
HerMiniMan
Apr 3, 2014 05:28 PM
minicooperman2012
Feb 21, 2013 05:38 AM
dabears
May 25, 2011 09:20 AM
