-   MCF Help & Suggestion Center (https://minicooperforums.com/forum/mcf-help-suggestion-center-7/)
-   -   03 Mini heat problem (https://minicooperforums.com/forum/mcf-help-suggestion-center-7/03-mini-heat-problem-4082/)
Janelle Feb 5, 2011 09:53 AM
Hi! I'm brand new here. I LOVE my BRIGHT:) yellow cooper. I got it at auction from somebody who wanted it to look like an S, but it's not. My heat monitor has pegged out a couple of times. Sometimes it comes down, and then back up, and then stays up. While I can see no leaks (used cardboard underneath). Have added fluid a few times. Also, when it is HOT, the cabin is cold.. When I add a little fluid, the cabin heater works again, and it goes back to midpoint.
HELP?
bad venge Feb 5, 2011 03:37 PM
I'd check/replace thermostat first
