2006 MCS JCW overheating in autocross
Old Feb 10, 2012 | 11:29 PM
jtcaoimh's Avatar
Default 2006 MCS JCW overheating in autocross
Considering extra, "pusher" fan. Anyone have ideas, suggestions, solutions?
Thanks, JT
Old Feb 11, 2012 | 03:18 PM
Try one of the wetter antifreeze additives and change/remove the Thermostat
Old Feb 11, 2012 | 08:27 PM
jtcaoimh's Avatar
Default Overheating
I'll see what I can do about the thermostat, also changed to 5-40 oil. Measured the fan room, that's not happening, read up on "water wetter," that's not going to happen either. Has anyone tried venting the hood?
Old Feb 12, 2012 | 08:01 AM
I've been running it in my show car and the water wetter alone dropped my temp 25 degrees , swapping to a lower temp thermostat dropped me another 20 degrees.
I've also read that you can get different radiator caps to hold more pressure ect to change cooling capacity
the water wetter is a cheap thing to try same as the thermostat if you drop the idle temps by 45/50 that gives more headroom for the autocross thats a short burst of heat
possibly that and icing down the radiator between runs as well
msfaam
Nov 1, 2014 08:08 AM
Brenpd
Mar 6, 2010 11:29 PM
dirtbagdc2
Oct 17, 2009 01:04 PM
TeamKO
Aug 30, 2008 11:59 AM
Okiesnake
Dec 8, 2007 10:49 PM
