2006 R50 Overheats and/or quits
Old Feb 5, 2012 | 07:42 PM
merchanb's Avatar
Default 2006 R50 Overheats and/or quits
2006 R50 with only 8,000 miles (really) overheats and/or refuses to run. Any suggestions?
Old Feb 6, 2012 | 03:28 PM
Have you checked radiator/ Antifreeze ? for proper levels
Do the electric fans kick on ?
need a little more background
Old Feb 7, 2012 | 04:52 PM
merchanb's Avatar
Radiator cooling appears fine. Fans continue to run even after ignition is switched off. Engine had refused to run several time prior to the overheating problem. Dealer has ordered new fuel pump???
May 1, 2015 03:33 PM
May 1, 2015 03:22 PM
Jun 12, 2014 02:30 PM
Bugoy06
Oct 29, 2012 08:59 PM
lisa's mini
Oct 18, 2010 04:36 AM
