2007 Mini Cooper rough idle, P0014 & P0015 Codes
Hello All,
I have a manual 2007 mini cooper. When you start it cold, the engine idles fine but when it warms up a bit, it gets really rough and at times cuts out. The check engine light is on and comes up with codes P0014 and P0015. Does anyone know what this is or could be because right now, I don't even know where to begin with it. P0015: Camshaft Position, Act B - bank 1, timing over retard P0014: Camshaft Position, Act B - bank 1, timing over advanc. Any help will be greatly appreciated! Thanks in advance, Sir Frank |
| All times are GMT -5. The time now is 05:38 AM. |
