2013 Clubman S coolant issue
Old Jun 27, 2024 | 05:32 PM
Speedo's Avatar
Default 2013 Clubman S coolant issue
Got an oil change ton Tuesday his week and the shop told me I had a minor coolant leak. Drove home in 100 F heat with the AC on. Today when backing out of the garage, I noticed a sizeable puddle of coolant and when checking the reservoir...I noticed it was low, so I topped it off. I started it up and could not find a source of the leak. There was some visible antifreeze on top of the trannie. I put the mini on my lift, took a pressure tester and at 12 psi could not find any source of the leakage...either above or underneath. Went for a short drive and put it back up on the lift, noticing minor antifreeze around the bottom of the trannie...on the left side of the engine. With a light and inspection mirror, the only area of seepage was where the drivers side heater hose (that goes through the firewall) connects to the thermostat. Below that connection is the general area that is wet. I am wondering several things... why no leakage under pressure? Why was the leakage amount considerably higher when it was hot and I was using the AC? Is the leakage at the thermostat connection typical of a failed gasket or O ring or bad thermostat, or just a leaky connection? Why is that heater hose connected to the thermostat at all? Is it more likely that the hose failed or the thermostat? How difficult is it to swap out the thermostat?
Oldcoastie
Apr 14, 2024 02:54 PM
Kevin Special-k Shaw
Mar 16, 2017 12:11 PM
Minicoop05
Sep 5, 2016 12:45 PM
nursecandy
Nov 23, 2012 09:24 PM
