1rickmini |
05-21-2011 05:06 PM |
Door Lock Problems
This is my problem. I have a 2005 Convertible S with only 25,000 miles on it. My drivers side door will not open when I try to open the door from the inside handle. I can only open it by using the unlock feature on the dash and then reaching out the window and opening the door from the outside handle.
The door will lock and unlock from the key remote but again the inside door handle will not release. I went to the dealer and was told I needed to replace the door actuator. My problem seems to be different then most I have read about online. I have also read some interesting comments about disconnecting the battery and resetting the system. However, someone stated this caused additional problems. Not sure why. Anyway, if anyone has any advice please let me know.
