| nursecandy |
Oct 27, 2012 10:59 AM |
Got a problem, looking for suggestions!
I have a 2008 mini cooper S, R56 with a disappearing coolant problem. Quite honestly I can't spare the big bucks it will cost to take it to a dealership to have it diagnosed, not the mention the nearest dealer is 100 miles away!
It started loosing coolant, slowly and with no obvious spots of fluid under the car, its driven 100 miles day and would require replacing about a quart of coolant almost daily. After doing some research, we bought and replaced the thermostat housing which had a thermostat and a temp sensor in it. It did ok for about a week, then suddenly coolant is POURING out. Ok, we figured a hose or bolt was loose, took it apart again and while we didn't find anything specific, we did replace hose clamps, tightened everything we could find. Now, its still loosing coolant, not as bad, but we cant find where its going, not majorly leaking though, AND the check engine is on (Glowing yellow, rather than red) and when checked, it codes something about the thermostat and its low on coolant???
I would so appreciate thoughts/suggestions while I come up with the money to spare to repair it. I hate going into a car repair shop with no clue as to what might be wrong with my vehicle, so I like to be prepared. And you know how car repair shops tend to treat a woman!
Thanks folks, I so appreciate your help!
