gotta question
Old Feb 19, 2013 | 03:10 PM
lynmcki's Avatar
Default gotta question
2003 Mini standard. Just clicks when I turn on the ignition. Can start by popping the clutch and once started it runs fine.....then will start all day when I stop for errands. Had the battery checked and the altimeter and all is good. Cleaned the battery cables and tightened. Still does it. What next?
Old Feb 19, 2013 | 04:11 PM
I'd have the battery rechecked with a load tester , sounds like it's weak to me.
If thats not it could be a starter /solenoid trouble or wiring there
