Alta Adjustable Drive Belt Tensioner Stop For Your R53!
Old Sep 25, 2015 | 04:17 PM
PelicanParts.com's Avatar
Default Alta Adjustable Drive Belt Tensioner Stop For Your R53!
MINI Cooper Forums! Upgrade your tensioner with Alta today!
The OEM belt tensioner dampener is very well known to cause lots of problems on your 2002-2006 MINI. The bushings wear out causing strange noises and dampener failure. When the dampener wears out, it causes instability in your belt tension, premature belt failure, shortened life of bushings and tensioner spring, and slippage under full throttle. Also, the OEM dampener can't protect your crank pulley and related parts from getting destroyed in the event a belt fails. When you replace the OEM hydraulic dampener with the ALTA Performance Tension Damper, more tension is added to the belt. The ALTA Performance Tension Damper eliminates tensioner bounce and adds more tension than the OEM dampener, allowing better performance and response under extreme driving conditions.
CLICK HERE to purchase yours today!
May 19, 2015 06:25 PM
sweetheat
Mar 16, 2015 01:26 AM
Jul 25, 2013 12:44 PM
Jun 25, 2012 11:23 AM
Jun 13, 2012 01:06 PM
