Belt Tensioner Replacement – Let’s Do It! By Pelican Parts
Old 07-25-2013, 12:44 PM
PelicanParts.com's Avatar
Default Belt Tensioner Replacement – Let’s Do It! By Pelican Parts
The MINI Cooper S uses a serpentine belt to drive the various ancillary components on the engine. This includes the alternator, A/C compressor and the supercharger/water pump. The serpentine belt is kept in place by a small dampener and a coil spring mounted to the end of an idler pulley. This is called a belt tensioner. Over time, the serpentine belt can stretch. The tensioner setup is designed to allow a certain amount of flex to account for stretching as well as vibration.
With a socket set & serpentine belt tool, you are less than two hours away from replacing your tensioner!
R50/52/53 & R55/56/57 Shop here for tensioners!
Follow these instructions for install guidance:
MINI Belt Tensioner Replacement
Let us know what questions you have!
Mark/Pelican Parts
05-19-2015 06:25 PM
10-02-2013 06:44 PM
04-23-2013 03:39 PM
06-25-2012 11:23 AM
06-13-2012 01:06 PM
Quick Reply: Belt Tensioner Replacement – Let’s Do It! By Pelican Parts
