Best Price Valve Covers!
Old May 19, 2017 | 03:34 PM
Default Best Price Valve Covers!
R55-R59 MINI Cooper S/JCW N14 Valve Cover Kits
A damaged valve cover can cause oil leaks, vacuum leaks, driveability problems, and a check engine light. Additionally, cracks and warping can result in a significant vacuum leak and result in very poor performance.
The MINI Gen2 R55-R59 N14 engine valve cover is prone to damage over time. For this part, an aftermarket replacement is not an option for which ECS supplies Genuine OEM MINI Valve Cover replacements for your car.
Fix that cracked & leaking valve cover
Fits:
R56 MINI Cooper S (2007-2010) / JCW (2009-2012)
R55 MINI Clubman S (2008-2010) / JCW (2009-2012)
R57 MINI Cooper Convertible S (2009-2010) / JCW (2009-2012)
R58 MINI Coupe' JCW (2012)
R59 MINI Roadster JCW (2012)
Click HERE For your MINI Cooper Options
R55-R61 MINI Cooper S/JCW N18 Valve Cover Kits
The MINI Gen2 R55-RR61 N18 engine valve cover is prone to damage over time. For this part, an aftermarket replacement is not an option for which ECS supplies Genuine OEM MINI Valve Cover replacements for your car.
Turn off that check engine light.
N18 engine
Fits:
R55-R59 MINI Cooper S/JCW (2011-2015)
R60-R61 MINI Countryman/Paceman S/SX/JCW (2011-2016)
MINI Gen2 R55-R57 N12 Valve Cover
The MINI Gen2 R55-R5 N1valve cover is prone to damage over time. For this part, an aftermarket replacement is not an option - ECS supplies Genuine OEM MINI Valve Cover replacements for your car.
Included in the kit are all necessary parts for a professional-level installation - a new valve cover gasket, valve cover seals for the spark plug tubes, and Oil cap & seal.
Got You Covered
Fits: N12 Engine
R56 MINI Cooper (2007-2010)
R55 MINI Clubman (2008-2010)
R57 MINI Cooper Convertible (2009-2010)
MINI R55 R56 R57 R58 R59 N16 Valve Cover
The MINI N16 valve cover is prone to damage over time. For this part, an aftermarket replacement is not an option - ECS supplies Genuine OEM MINI Valve Cover replacements for your car.
Fits: N16 Engine
R56 MINI Cooper (2011-2013)
R55 MINI Clubman (2011-2014)
R57 MINI Cooper Convertible (2011+)
R58 MINI Coupe'(2012+)
R59 MINI Roadster (2012+)
