Clutch Issues? Clutch Super Kits For Your MINI! by Pelican Parts
Old May 3, 2013 | 11:32 AM
PelicanParts.com's Avatar
Default Clutch Issues? Clutch Super Kits For Your MINI! by Pelican Parts
Now available from Pelican is our clutch super kit for the MINI. In this kit, you get everything you need to replace your clutch all at once. All the parts contained in the kit are either OEM or Genuine MINI parts. If you are spending the time and effort to pull your engine out of your car, you might as well make sure that you are replacing and fixing every piece that might need attention, while you have access to it. Here's what the kit includes:
- Three piece clutch kit
- New Pressure plate bolts
- New flywheel bolts
- Clutch disc centering tool
- New crankshaft rear seal (aka flywheel seal)
- New Transmission Main Shaft seal
- New release fork bushings (Cooper (2002-6/04), Cooper S (2002-06), Cooper S Conv. (2005-08))
- New throwout bearing guide sleeve (Cooper (2002-6/04), Cooper S (2002- 06), Cooper S Conv. (2005-08))
- New clutch pivot pin (Cooper (7/04-06), Cooper Conv. (2005-08))
- New slave cylinder
Applies to:
R53 MINI Cooper S (2002-06)
R52 MINI Cooper S Convertible (2005-08)
To find out more, Click Here to view the catalog
Jul 7, 2015 12:56 PM
May 7, 2015 12:20 PM
May 6, 2013 04:40 PM
May 1, 2013 01:39 PM
Apr 29, 2013 03:29 PM
