Cravenspeed Adjustable Short Shifter Available at Pelican Parts!
Make Everyday Driving less Everyday
When you upgrade to this fully Adjustable Short Shifter, you won't miss a shift but you might miss shifting. MINI made a great car for the masses but you want your MINI to drive exactly the way you want it to. It would be crazy if the seat and steering wheel didn't adjust to your comfort, so why shouldn't the shifter.
The ONLY Shifter That Adjusts at Your Request
The Adjustable Shifter from Craven Speed is the only short shifter that gives you the option to set and re-set the shift length and height at ANY TIME. Just as quickly as you can adjust the seat or mirrors, you can change the feel of this shifter. A locking collar sits near the base of the shifter and requires only a twist before the height and throw can be adjusted to your liking. You don't even need to look at what you are doing; with with our unique design, you cannot over adjust the shifter. Go ahead and move it from top to bottom without damaging your transmission.
Precision Made Parts From High Quality Materials
You should never expect anything else from us. We make our parts here in the USA, and we make them with care. Hybrid designed and CNC machined from Stainless Steel, and 6061 Aluminum; it is guaranteed to be unbreakable. The kits for the 2007+ models come with machined 6061 aluminum bushings as well. Make the feel of each shift more crisp after you replace the rubber bushings with these perfectly machined replacements.
Jul 7, 2015 12:56 PM
May 19, 2015 06:25 PM
