:: ECS Tuning :: Gen 3 F56 / F55 ECS Wheel Spacer Kits & GP2 Brake Lines
ECS Tuning ECS Wheel Spacer Kit ; Gen 3 MINIs Spacers for your racer. ECS Tuning lets you tweak your stance - or swagger down the road with a larger 15 - 20mm spacer. Choose from our huge inventory of hub centric spacers in thicknesses sure to match your car, your wheels, and your shopping budget. All ECS MINI spacers are aluminum, and are black anodized for corrosion protection. Kits come with correct-length black lug bolts for a complete package. Click below for you model. http://www.ecstuning.com/marketing/M...0142016_01.jpg Click HERE For F56 MINI Cooper, Cooper S, JCW (2014+) Options & Click HERE For F55 MINI Cooper, Cooper S, JCW (2015+) Options How To Measure For ECS Tuning Wheel Spacers : Before you order to get the correct size front and rear !!! ------------------------------------------------------------------------------------ R56 MINI JCW Gp2 ECS Tuning Exact-Fit Brake Lines If you spend time and money renewing your brake hardware and linings, use this time to upgrade to the stellar ECS Tuning Exact-Fit brake hoses, and do the job right. The premium brake hoses are significantly stronger, more reliable, and better protected than those supplied from the factory. Shielded in stainless steel mesh reinforcement, and coated with bright red vinyl for added protection, the lines look as good as they perform. Available by the axle for front or rear, or as a complete vehicle set Click below for you model. http://www.ecstuning.com/marketing/M..._011316_01.jpg Click HERE For R56 MINI Cooper JCW GP2 Options |
Get the fitment you have wanted !
Bumped
| All times are GMT -5. The time now is 09:17 AM. |
