:: ECS Tuning :: MINI GEN 2 JCW N18 Forge Diverter Valve Upgrade
http://www.ecstuning.com/forum/bmw/ecs800header.jpg MINI GEN 2 JCW N18 Forge Diverter Valve Upgrade Stock diverter valves just can't handle performance upgrades. Add a little boost and they get all weak in the knees and go to pieces. Forge knows this. That's why they've engineered boost-hardy blow off and diverter valves tough enough to take the pressure without blowing their lids. If an ECU upgrade or other engine aspiration upgrade has significantly altered your manifold boost pressure, or if you're looking to stave off future diverter valve failures, the Forge kit is the wisest solution. Forge has even included an install PDF on a flash drive to make installation simple. Forge Ahead. Fits: N18 engines R56 MINI Cooper JCW (2013+) R55 MINI Cooper Clubman JCW (2013+) R57 MINI Cooper Convertible JCW (2013+) R58 MINI Coupe' JCW (2013+) R59 MINI Roadster JCW (2013+) http://www.ecstuning.com/marketing/M...rter_Valve.jpg Click HERE for Forge kits |
| All times are GMT -5. The time now is 10:35 AM. |
