:: ECS Tuning :: MINI R55 R56 R57 R58 N16 Engine Timing Chain Kits ( Cooper NON S )
http://www.ecstuning.com/forum/bmw/ecs800header.jpg MINI R55 R56 R57 R58 N16 Engine Timing Chain Kits ( Cooper NON S ) Accurate and reliable engine timing requires the cooperation of several critical components. Wear is typically systemic - meaning as one component wears significantly, other parts begin to lose functionality and fail, beginning a cumulative effect of system failure. To avoid the catastrophic consequences inherent in timing system failure, invest in an ECS assembled Timing Chain Kit. The ECS kit includes carefully selected components for a thorough refresh - a new timing chain and chain tensioner, timing chain guide rails, inlet cam bolt, outlet cam bolt, and crankshaft gear. Right on Time its: N16 Engine R56 MINI Cooper (2011-2013) R55 MINI Clubman (2011-2014) R57 MINI Cooper Convertible (2011+) R58 MINI Coupe' (2012+) R59 MINI Roadster (2012+) http://www.ecstuning.com/marketing/M...ing_Chains.jpg Click HERE For Timing Chain kit |
