:: ECS Tuning :: MINI R55 R56 R57 R58 N18 Engine Timing Chain Kits ( Coopes S )
http://www.ecstuning.com/forum/bmw/ecs800header.jpg MINI R55 R56 R57 R58 N18 Engine Timing Chain Kits ( Coopes S ) Accurate and reliable engine timing requires the cooperation of several critical components. Wear is typically systemic - meaning as one component wears significantly, other parts begin to lose functionality and fail, beginning a cumulative effect of system failure. To avoid the catastrophic consequences inherent in timing system failure, invest in an ECS-assembled Timing Chain Kit. The ECS kit includes carefully selected components for a thorough refresh - a new timing chain and chain tensioner, timing chain guide rails, inlet cam bolt, outlet cam bolt, and crankshaft gear. Right on Time Fits: N18 Engine R56 MINI Cooper S (2011-2013) R55 MINI Clubman S (2011-2014) R57 MINI Cooper Convertible S (2011+) R58 MINI Coupe' S (2012+) R59 MINI Roadster S (2012+) http://www.ecstuning.com/marketing/M...ing_Chains.jpg Click HERE For Timing Chain Kit |
