:: ECS Tuning :: MINI R60/R61 Pierburg Pressure Converter
http://www.ecstuning.com/forum/bmw/ecs800header.jpg MINI R60/R61 Pierburg Pressure Converter Feeling a little sluggish? The performance of your MINI thrives on the ability of the turbocharger. Even the smallest of pressure leaks can slow you down and turn your check engine light on. Don't let any of that power get away with a worn pressure transducer. A common problem with turbo control systems, this Pressure Converter from Pierburg will bring your boost levels back to where they should be, and help get rid of that annoying check engine light! Now more affordable than ever from the OEM manufacturer, fix vacuum leaks and boost problems with one simple repair Under Pressure? Fits: R60 MINI Countryman S/SX/JCW (2011+) R61 MINI Paceman S/SX/JCW (2013+) http://www.ecstuning.com/marketing/M...60_R61_PPC.jpg Click HERE For Peirburg |
