:: ECS Tuning :: R55-R57 MINI Viaco Lower Control Arm Bushings
http://www.ecstuning.com/forum/bmw/ecs800header.jpg R55-R57 MINI Viaco Lower Control Arm Bushings Is your MINI Cooper making noises over bumps, or does your steering feel loose and less responsive than it once was? The control arm bushings are a big cause of front suspension problems, and the only remedy is to replace them. This kit was built by the experts at ECS Tuning, and it includes both lower control arm/wishbone bushings. Both bushings are already pressed into their brackets, so you won't have to worry about renting or buying the equipment needed to press the bushings in. Fix your front suspension issues today with this kit from ECS Tuning. The Best Remedy Fits: MINI R56 Cooper /S (2007+) MINI R55 Clubman /S (2008+) MINI R57 Cooper Convertible /S (2009+) MINI R58 Coupe' /S (2012+) MINI R59 Roadster /S (2012+) http://www.ecstuning.com/marketing/M...m_Bushings.jpg Click HERE for LCAB kit |
