:: ECS Tuning :: Schwaben Coolant Evacuation Tool Kit|Bleed Easy
http://www.ecstuning.com/forum/bmw/ecs800header.jpg Fresh coolant is paramount to safe & reliable engine operation. The process of bleeding the air out of your cooling system during a coolant refresh is tedious & therefore often neglected. ECS offers a highly convenient solution to the tedium & frustration associated with coolant servicing – the Schwaben Coolant Evacuation Kit. Insert the tool into the radiator service neck, attach the included Venturi adapter & allow the system to reach 25 psi, drawing out the vacuum. Use the same tool to fill your radiator, allowing the pressure to resume to 0 psi, completing the procedure. http://www.ecstuning.com/marketing/U...n_Tool_Kit.jpg Click HERE for your Schwaben Coolant Evacuation Tool Kit |
