-   -   :: ECS Tuning :: Schwaben Tools | Brake Caliper Essentials (https://minicooperforums.com/forum/member-group-special-buys-27/ecs-tuning-schwaben-tools-%7C-brake-caliper-essentials-6584/)
ECSTuning Nov 1, 2013 01:36 PM
http://www.ecstuning.com/forum/bmw/ecs800header.jpg
Rule #1: Use the right tool for the job. These brake caliper tools from Schwaben are essential for changing your pads or bleeding your brake fluid in your German automobile.
If your caliper pistons need to be simply pressed back in, or if they're threaded and require screwing back in, we've got the caliper piston tool you want.
Bleeding your brakes? Our Schwaben brake bleeder wrench makes it so easy, you can even do it without having to remove your wheels!
Make sure you're prepared with the right tool for the job with these Brake Caliper Essentials from Schwaben Tools.
Brake out the right tools.
Universal fitment.
http://www.ecstuning.com/marketing/G...iper_Tools.jpg
Click HERE to order or for more information.
