Engine Mounts Shot? OE Replacements In Stock & DIY by Pelican Parts
Old May 8, 2013 | 12:55 PM
PelicanParts.com's Avatar
Default Engine Mounts Shot? OE Replacements In Stock & DIY by Pelican Parts
One of the most common parts to deteriorate on the MINI are the engine mounts. The rubber that is contained within the mounts becomes old and brittle, and doesn’t perform a good job of isolating the drivetrain from the rest of the chassis. This eventually can cause a whole host of problems and cause wear to other critical components. In the later MINIs (2004 on), they use a liquid filled engine mount on the passenger side that can leak and eventually collapse.
Pelican Parts stocks engine mounts as well as transmission mounts for your MINI!
- R50 MINI Cooper (2002-06)
- R53 MINI Cooper S (2002-06)
- R52 MINI Cooper Convertible (2005-08)
- R52 MINI Cooper S Convertible (2005-08)
Shop now HERE!
Check out the step-by-step DIY article HERE!
Nov 27, 2013 06:00 PM
Oct 8, 2013 07:36 PM
Jul 11, 2013 11:57 AM
May 21, 2013 07:20 PM
May 1, 2013 01:39 PM
