Fumoto Drain Plug Valve For Your R52 MINI Cooper
ECS Tuning Fumoto Drain Plug Valve For Your R52 MINI Cooper The Fumoto 14mm oil drain valve replaces your OE drain plug for fast, easy oil changes. Includes a threaded brass extension for oil pans with recessed drain plugs. The Fumoto oil drain valve features a ball valve with tight tolerances to ensure it will not leak once lubricated. Initially, you may wish to use a pair of pliers or a glove to turn the valve, as the valve will be stiff until lubricated during the first oil change. Push-N-Turn-N-Done! Fits: R52 MINI Cooper Convertible S / JCW ( 2005-2008 ) http://c1521972.r72.cf0.rackcdn.com/...2704_large.jpg Click HERE For FUMOTO |
