Get maximum power gains with aFe Mach Force Exhaust System!
Looking for the easiest and the most effective way to get maximum power gains from your Mini 2014-2017? By ditching your restrictive factory stock exhaust and replacing it with aFe Mach Force XP™ 304 SS Cat-Back Exhaust System you'll see astonishing gains up to +11 horsepower and +14 lbs. x ft. of torque. This system performs much better than your stock exhaust and provides up to 29% greater exhaust flow.
Main features: - Constructed from 100% TIG-welded, 3"" into 2-1/2"" mandrel bent 304 stainless steel tubing - Incorporates a 3” into 2-1/2” dual exit mitered split - Utilizes dual high flow transverse mufflers for an aggressive sound - Includes dual 3-1/2"" diameter, black, stainless steel tips with laser-etched aFe power logos - Uses all factory hanger locations for a hassle free installation - Backed by a 2-year limited warranty. The smooth curves and increased diameter of this exhaust system helps remove restriction and keeps exhaust gas flowing smoothly for increased horsepower and torque. Thanks to the straight-through designed, free-flowing stainless steel muffler it has you will be able to get powerful sound and unleash all the power your Mini is capable to create. aFe® 49-36331-B - Mach Force XP™ 304 SS Cat-Back Exhaust System http://www.carid.com/images/for-foru...afe-mini-1.jpg http://www.carid.com/images/for-foru...afe-mini-2.jpg http://www.carid.com/images/for-foru...afe-mini-3.jpg http://www.carid.com/images/for-foru...-radiators.jpg Don't look any further, aFe Mach Force XP™ 304 SS Cat-Back Exhaust System has everything to meet your performance needs and exceed them! |
